# Webhook - Reciving software and store in sql
**URL:** <https://community.particle.io/t/webhook-reciving-software-and-store-in-sql/21995>\
**Category:** General\
**Created:** [April 11, 2016, 8:12am UTC](https://community.particle.io/t/webhook-reciving-software-and-store-in-sql/21995 "2016-04-11T08:12:11Z")\
**Showing post:** 3
**Author:** ![rickkas7](https://sea2.discourse-cdn.com/flex026/user_avatar/community.particle.io/rickkas7/32/8681_2.png) [@rickkas7](https://community.particle.io/u/rickkas7)\
**Post date:** [April 13, 2016, 8:36am UTC](https://community.particle.io/t/webhook-reciving-software-and-store-in-sql/21995/3 "2016-04-13T08:36:08Z")
Also, if you’re going to run your own server, you also have the option of not using a web hook at all. Your server can subscribe to the events directly using server-sent events (SSE). Once you have the the data from the events you can do whatever you want with it, including storing it in a SQL database. I do it using Java, but you can use node.js, PHP, Python, whatever you like.
_[View the full topic](https://community.particle.io/t/webhook-reciving-software-and-store-in-sql/21995)._
