I created a webhook integration to send data from the particle board to our private cloud, however I always get the following error: “connect ECONNREFUSED”, while testing the integration from https://console.particle.io/integrations/webhooks/
Our HTTP REST API works great, it has been tested and it is operational receiving data form other sources, however, my tests from Particle Console keeps failing.
I have disabled the injection of the additional fields, and disabled forcing SSL, nothing makes it work.
Would you know what usually could cause that error?
This is exactly what I have in my JSON field:
“avgSnr”: “33.33”,
“duplicate”: false,
“lat”: “44.44”,
“lng”: “55.55”,
“networkAssetCode”: “17AB05”,
“payload”: “48;27;1005;24.10;81.234”,
“rssi”: “22.22”,
“seqNumber”: 4,
“srn”: “11.11”,
“station”: “27CE”,
“time”: 1488933651
Thank you!
