Web App Login problem
When I login the the web IDE (build.particle.io) on my W10 computer, I enter my password and it keeps switching between authenticating and a redirect in a loop every one or two seconds. It just keeps going and never stops. If I use the same login at work on my W7 machine, no problem. I have tried both Chrome and Edge on my W10 machine.
build.particle.io/build
Then
https://login.particle.io/login?redirect=http://build.particle.io/build
Then
Then
build.particle.io/authenticate
This process never stops
I have had that too.
Can’t quite remember what the reason was but for me it helped to go to console.particle.io and log out there and then log in again.
Another thing you could check might be your password manager. Maybe it’s trying to auto-login with wrong credentials.
