Over the last few days I have been working on a simple little project to monitor my energy usage at home. A project I have called watz: https://github.com/scottsweb/watz
watz is a WiFi smart meter / pulse counter. It mounts to the LED on your electricity meter and measures the number of pulses in a given time period. This is used to generate real time power information. This data is periodically pushed to the Particle cloud and can be subscribed to via server-sent events.
My meter is based in a cupboard outside the house so powering the project is tricky. I have tried to optimise the code for power efficiency - pushing data every 15 minutes with WiFi off most of the time. I have a small solar panel and battery but I feel these are still only going to give a few days at the current rate (it is winter and there is very little sun at the moment).
What I may try and do is up the interval for data collection but send the data in batches every 6 hours or so. Any tips would be appreciated.
As I’m fairly new to programming, it helped me do what I have been trying off and on to do with my Cores for over a year. I did not manage to get your code to run on my Core, so I have modified it to work without flashee. My meter is located indoors with a power outlet nearby, so I had no use for the power saving solutions that you have implemented.
I’m publishing the data every minute, relaying the data via Node-RED to emoncms running on my NAS.
// Puls counter for energy-meter based on https://github.com/scottsweb/watz
SYSTEM_MODE(AUTOMATIC);
// pins
int intled = D7;
int sensor = D0;
// general vars
char json[64];
// pulse vars
void pulseInt(void); // function for interrupt
float pulseCount = 0; // counts power pulses on sensor
Particle.connect();
// set led as output
pinMode(intled, OUTPUT);
// set sensor as input
pinMode(sensor, INPUT);
// attach interrupt to LED pin, when RISING
attachInterrupt(sensor, pulseInt, RISING);
// publish once every 1 minutes
if (Time.second() == 30)
noInterrupts(); // Disables interrupts while publishing data
float avgInterval = 60 / pulseCount;
float kw = 3600 / (avgInterval * 1000);
sprintf(json,"{\"kw\": %.3f, \"count\": %.0f}", kw, pulseCount);
Particle.publish("watz", json, 60, PRIVATE);
pulseCount = 0;
delay(1500); // delay more than 1000ms so that the data on second 30 is only published one time
interrupts(); // Re-enables interrupts when data is published
void pulseInt() {
// visually indicate the blink has been detected on internal LED D7
digitalWrite(intled, HIGH);
delay(100);
digitalWrite(intled, LOW);
// increment pulse count
pulseCount++;
