VisualStudio Tutorial?
Is there a tutorial (or any documentation) here on getting VisualStudio setup to work with a Photon module? If it matters, I got the particle-cli installed.
Hi @burnettm,
the only manner we found here in our lab is to install the toolchain for windows and compile the entire framework. After, you can flash your device with this custom firmware.
Maybe it’s not the best solution but it works and you can use VS to write code.
Valere
