Variable types: byte in data structure & OneWire library
I’ve recently been working on some Photon projects that include DS18 OneWire sensors. I have successfully used the OneWire library and the following lines of code in my project to get temp readings;
byte DS18_01[8] = { 0x28, 0xFF, 0x07, 0x85, 0x83, 0x17, 0x04, 0x24 };    //address of DS18_01 sensor
degF = getTemp(DS18_05);
I would like to use a data structure as follows;
struct device {
  byte address;
  String label;
  String status;
} devices[20];      //up to 20 OneWire DS18 sensors
  devices[1].address = 0x28, 0xff, 0x07, 0x85, 0x83, 0x17, 0x04, 0x24;
  devices[1].label = "DS18_01";
  devices[1].status = "Offline";
I am confused by how to assign a value to the address so that it can be used in this line of code;
I tried degF = getTemp(device[1].address);
This doesn’t work and if I Serial.print the value of device[1].address it is 40.
Thanks in advance for any help & guidance!
Dale
Where does DS18_05 come from?
I see DS18_01 but not _05
In your struct address is only one byte, but you intend to assing eight - how would that work?
Oops…I have 20 sensors DS18_01 thru DS18_20. I pasted the wrong sample line of code.
How do I set address to 8 bytes in the data structure? If I code each address like this;
byte DS18_01[8] = { 0x28, 0xFF, 0x07, 0x85, 0x83, 0x17, 0x04, 0x24 }; it works. But, I want to be able to call getTemp using the device[#].address variable.
Just as you did in your working example
byte address[8];
The assignment works just the same way as there with = {...}
And if you want to initialise the struct you'd just do
struct device {
} devices[] =
{ { 0x28, 0xff, 0x07, 0x85, 0x83, 0x17, 0x04, 0x24 }
  , "label 1"
  , "status 1"
Thank you!
