I’ve used that library on this page. There’s also local storage included, should you be interested.
Thank you!
I keep getting this error when trying to install spark.js.
I have CLI installed and its working fine.
@Moors7
The link for your example page opens fine on my phone. But does not show me the button when i open it using Chrome on my Desktop.
I just installed the latest Node.js on a clean system and get the same errors. Disregarding that, I do find the Library in there.
You should be able to find them in the directory_you_were_in\node_modules\spark
path. Depending on what you want to do, you might not even need them like that. You can use the CDN to include the minified library into your webpage, if that’s what you’re making.
I also installed the latest Chrome version in which I do see the button. Not sure what’s going on there. Works in Edge, Chrome, Opera, (mobile) Safari at first glance. Haven’t tried others as of yet. The code is on GitHub as well, Should you find that easier.
Yea i will use CDN. The button doesnt show in Chrome or Firefox on another computer. It shows on my iphone. its connected to the same network. What im trying to make is a webapp that can use one login page and carry over DeviceID and Token over multiple pages. Pages would have Post events and Publish events.
Hi @Ali
When I have problems with Chrome (in particular) and Firefox, I always try incognito mode. Chrome in particular tries to cache lots of junk other browsers don’t and it can cause problems. These days when I want to run the web IDE, I always just start it in incognito mode to avoid problems, for instance.
Its not just Chrome. The browsers don’t seem to be downloading spark.min.js Couldn’t get anything to work. I just pointed the source to read locally to get it working for now
Hi again,
@andreh posted an amazing WEBAPP written in Angular Here. I modified the files to work for my project. He has however been missing on the forum and i desperately need some help with getting my publish events working. I am a novice at everything programming. His app.js file has a function for events built into it.
/** Register a handler which will be called for each incoming event from any owned device. */
registerMineEvents: function(handler) {
this.registerDeviceEvents('mine', handler);
publishEvent: function(event) {
return $http.post(baseUrl + '/devices/events', event);
and he uses ng-repeat to show all the events in a list format.
<div ng-show="events[device.id] && events[device.id].length > 0">
<h3>Events</h3>
<table class="table">
<thead>
<tr>
<th class="hidden-xs">Time</th>
<th>Event</th>
<th>Data</th>
</tr>
</thead>
<tbody>
<tr ng-repeat="event in events[device.id]">
<td class="hidden-xs">{{event.published_at}}</td>
<td>{{event.name}}</td>
<td>{{event.data}}</td>
</tr>
</tbody>
</table>
What if i want to show specific events by themselves instead of them creating sequential duplicates and update those events whenever a new value is pushed as per the programming in Photon. Kind of like the tutorial you did.
Any help will be greatly appreciated as i am quite stuck.
Hi @Ali
I am not an angular.js user so maybe @Moors7 or someone else could help more.
Here is how you register for the events and do the initial JSON parsing:
eventSource.addEventListener('EventNameHere', function(e) {
var rawData = JSON.parse(e.data);
var parsedData = JSON.parse(rawData.data);
}, false);
Where I put ...
you need to add code to find your table (I would name it and use getElementById) and then add data to it (I would use the insertRow method of the table).
I figured out how his works. Angular has a filter option that can be used to call up specific events.
ex:
<tr ng-repeat="event in events[device.id] | filter: 'yourEventName' ">
Hello,
Nice and usefull tuto.
I can't manage to read those data with Particle.subscribe() on another particle.
Data is received, but no way to translate the data (char) in different integer to pass data from one device to another.
Any idea ?
Hi @sylvaing
In Javascript, lots of functions take strings and automatically convert them to integers. See this page for details:
In this case it seems like the Javascript like this is what you want:
var myInt = parseInt( parsedData.myJSONField );
thx for your answer, but i want to receive and compute those data in my photon, ie not in javascript. I’m strugling with sscan() finction without any results for the moment.
like that:
scanf(data,"%u,%u,%u,%u",&buddyLightValue,&buddyLightValue,&buddySoundValue,&buddyMoveValue,&buddyPushValue);
If you provide the actual input string and the exact code you use, we might be able to help.
It’s sscanf()
you want, and you should have same amount of receiving variables as you have place holders in the format string and you’d need to check the return value of sscanf()
to know how many of your variables could be filled successfully.
yes sorry, i did use sscanf() without any good result.
Here is my code:
int led = D0;
int boardLed = D7;
int lightsensor = A0;
int soundsensor = A1;
int movesensor = A2;
int pushsensor = A3;
int power = A5;
int sensorValue = 0;
int needUpdate = 1;
int lightValue = 0;
int soundValue = 0;
int moveValue = 0;
int pushValue = 0;
int buddyLightValue = 0;
int buddySoundValue = 0;
int buddyMoveValue = 0;
int buddyPushValue = 0;
char message[40];
char receivedMessage[40];
char myName[12] = "lehio_3";
char buddyName[12] = "lehio_3";
pinMode(led,OUTPUT); // Our LED pin is output (lighting up the LED)
pinMode(boardLed,OUTPUT); // Our on-board LED is output as well
pinMode(power,OUTPUT); // Our on-board LED is output as well
Particle.subscribe(buddyName, myHandler);
analogWrite(power,4095); // max 4095
delay(5000); // 1000 = 1s - So scan every 5 sec
// light data analysis
sensorValue = analogRead(lightsensor)/16; // from 0-255
analogWrite(led,sensorValue);
if (sensorValue != lightValue) {
needUpdate = 1;
lightValue = sensorValue;
// Here other data analysisi... (deleted)
// send datas only if required
if (needUpdate == 1) {
sprintf(message,"%d,%d,%d,%d",lightValue,soundValue,moveValue,pushValue);
sprintf(message,"%d",lightValue);
Particle.publish(myName,message);
needUpdate = 0;
void myHandler(const char *event, const char *data)
Particle.publish("debug1",data); // Here I have the requires data
sscanf(data,"%u,%u,%u,%u",&buddyLightValue,&buddyLightValue,&buddySoundValue,&buddyMoveValue,&buddyPushValue);
sprintf(message,"%d",buddyLightValue);
Particle.publish("debug2",message); // HERE IT DON'T WORK...
Hi @sylvaing
Here some things that are wrong in your code:
Are you really using JSON structure in your publish? A JSON is a structure text representation that uses field names in double-quotes, followed by a colon, followed by the data. Your sscanf parameter string does not follow this format at all.
As @ScruffR pointed out above, you have four %u’s in your string but are passing five integer addresses.
The first integer address is repeated. I cannot imagine that this gives good, repeatable results.
After reformatting your code it seems as if there is an error with your curly braces in the last function too.
You are using "%u
" but have signed int
as receiving variables. Is this intentional?
analogWrite()
on a non DAC pin like your power
(A5) supports max 255 and not 4095 as you use in this
What's the point of the first printf()
in this?
needUpdate = 0;
What exactly "don't work"?`
I can't see this in your post.
What does the string you actually receive look like?
What do you see published as debug1
and debug2
We can guess what it should look like from reading the code and we could flash your code to our own devices and try, but since you already got that data, just post it.
Also with a description what you'd expect it to look like.
Hello and thank’s for this help. Sorry i had so many changes in this code that it took me some time (and a broken internet access…). Thank’s for your patience.
The aim: each device have 4 sensors, and should send it’s data (int) to the other. As @bko wrote it, I’m not currently using a JSON structure but would be ok to do it, but i’m currently not able to translate the data (one char) from the cloud in multiple integer.
I’m using also particle.publish() to debug, here is what I currently get (after your corrections @ScruffR):
lehio_3 - 0,60,71,94 // as expected
debug1 - 0,60,71,94 // as expected
debug2 - 536871772,536871760,536871748,536871780 // UNEXPECTED
Here is the full & corrected code:
int led = D0;
int boardLed = D7;
int power = A5;
int needUpdate = 1;
int lightValue = 0;
int soundValue = 0;
int moveValue = 0;
int pushValue = 0;
char message[40];
// SETUP
// Register to buddy
analogWrite(power,255); // max 4095
needUpdate = 1;
// sound data analysis
sensorValue = analogRead(soundsensor)/16; // from 0-255
if (sensorValue != soundValue) {
needUpdate = 1;
soundValue = sensorValue;
// move data analysis
sensorValue = analogRead(movesensor)/16; // from 0-255
if (sensorValue != moveValue) {
needUpdate = 1;
moveValue = sensorValue;
// push data analysis
sensorValue = analogRead(pushsensor)/16; // from 0-255
if (sensorValue != pushValue) {
needUpdate = 1;
pushValue = sensorValue;
Particle.publish(myName,message); // sendind data to the cloud eg:
needUpdate = 0;
sscanf(data,"%d,%d,%d,%d",&buddyLightValue,&buddySoundValue,&buddyMoveValue,&buddyPushValue);
sprintf(message,"%d,%d,%d,%d",&buddyLightValue,&buddySoundValue,&buddyMoveValue,&buddyPushValue); // just to verify the data
Thank’s for this help!
On that point that was a test, the example below is using %d which is required as I understood.
Thx
