Using simple photon firmware on argon?
Hi there, this is probably simple but i’m new to this. Is there any necessary updates to photon firmware for i2c interfacing to make it work on an argon? Nothing is published or updated after the initial publishes. The code i’m referring to was taken from here; https://particle.hackster.io/macsboost/bme280-thingspeak-particle-bridge-4d7dd4
There shouldn't be any necessary modifications to the application, but you should make certain whether you have the BME280 wired correctly to the Argon.
Try using the serial monitor to get more debugging information.
