Is it possible to use Particle boards without an account in the Particle.io?
I don’t want to be tied to the Particle.io backend.
You can use raw TCP and UDP with the Particle cloud disabled on both Wi-Fi and Cellular devices. You don’t need to have an account and you can flash by USB.
For Wi-Fi devices there’s also the unsupported local cloud and also a better maintained fork by a community member.
