Update - Device OS 0.9.0 for Gen3 devices
BUGFIXES
- [Gen 3] Fixes system-dynalib incompatibility introduced in 0.9.0-rc.1, causing pre-0.9.0-rc.1 user applications that call certain system-dynalib functions to crash the device [#1692]
- [Gen 3]
WKP
pin is configured as pull-down with rising edge trigger when entering STANDBY sleep mode to keep feature parity with Gen 2 devices (#1691) - [Boron] PPP thread stack size increased by 1K in order to resolve a very rare stack overflow (#1691)
- [Gen 3] Fixes a crash when attempting to send constant data residing in flash through Ethernet interface (#1691)
- [Gen 3] An attempt to unitialize an SPI interface no longer causes an assertion failure if the interface is not initialized (#1663)
- [Gen 3] Default SPI settings are now recognized correctly (#1663)
- [Gen 3] Fixed a possible race condition during the Timer’s uninitialization (#1663)
- [Gen 3]
random()
is now properly seeded on application startup (#1663) - [Boron] Fixes an issue with IMEI and ICCID not being reported in listening mode serial console with
v
command (#1681) - [Gen 3] SPI MISO is no longer configured with a pull-down and user-provided CS pin is not reset to
INPUT
state when reconfiguring SPI peripheral (#1671) - [Argon] Fixes a deadlock when initializing NCP client (#1661)
- [Gen 3] DFU mode no longer requires driver installation on Windows. Fixes incorrect WCID descriptors (#1653)
- [Gen 3] Adds missing Arduino-specific definitions (#1658)
- [Xenon] Makes
Serial2
available in user applications (#1660) - [Argon] WiFi cipher types are now being correctly reported when scanning or retreiving stored credentials (#1659)
ENHANCEMENTS
- [Gen 3]
micros()
resolution increased by mixing inDWT->CYCCNT
(#1682)
FEATURES
- [Gen 3] STOP sleep mode support (#1682)
- [Gen 3] STANDBY sleep mode support (#1667)
- [Gen 3] USB control requests (#1655)
- [Gen 3] Mesh network diagnostics (#1657)
- [Boron]
Cellular.command()
support (#1651)
INTERNAL
- [Gen 3] Most of the
wiring/no_fixture
tests now successfully run on Xenon, Argon and Boron (#1663) - Removed strong dependency on
git
(#1664) - [Gen 3] OpenThread updated to 20190130 master with the fix for negative clock drift between HFCLK and LFCLK (#1684)
- Submodules now use absolute https URLs (#1699)
- Fixed an assertion failure (SOS 10) with Mesh.subscribe() and threading enabled (#1652)
