Undersanding Series and parallel resistors
In order to better understand of the project, I checked some resources of what is the difference between the Resistor in Series and in parallel.In the circuit shown, find the current in each resistor and the values of the potential at points A, B, and C.
First I computed the combined resistance of the parallel resistors and got 4.54 kOhms. Then I added this to 10.5 to get 15.04 kOhms total resistance. So from Ohm’s law, the total current is I=V/R = 16.5 / 15040 = 1.0971 x 10-3 A. I get potentials at A, B, and C of 16.5, 11.5, and 0 volts. I think this is correct so far. To find the current through each resistor: For the 10.5 kOhm resistor, since it is in series, it makes sense to me that the current through this resistor must be equal to the total current: 1.0971 x 10-3 A. And that the current running through the parallel pair must also be 1.0971 x 10-3 A. But the voltage across this resistor is 16.5-11.5, or 5v. Using Ohm’s law, I=V/R, I get 5/10500 = 0.000476 A Which way is correct??? Thanks
The voltage drop between B and C is 11.52 V not 5 V, hence you need to calculate 11.52V / 10500 Ohm which is the expected 1.097 mA.
The 4.98V are dropped from A to B and consequently the the current divides into 0.874 mA in the top branch and 0.223 mA in the bottom branch adding up again to 1.097mA.
Hi there. Are you using Particle products in your project? Please let us know.
To answer your question:
I agree with your math and you, I believe, already solved the answer to your question. Referring back to your original statement of voltage potentials:
The correct voltage potential (junction B) would be 11.5 volts. (There is no 5 volt potential.)
The series circuit BC begins with voltage potential 11.5 and ends with 0.
There may be some confusion by using the term difference in voltage drop. In addition to Ohm's Law, it is also good to be familiar with Kirchhoff's Voltage Law. The Three Rules of a Series Circuit & The Three Rules of a Parallel Circuit. Hey, it is all good stuff!
