# Unable to use USBSerial for Raspberrypi
**URL:** <https://community.particle.io/t/unable-to-use-usbserial-for-raspberrypi/30876>\
**Category:** Raspberry Pi\
**Created:** [March 23, 2017, 4:42pm UTC](https://community.particle.io/t/unable-to-use-usbserial-for-raspberrypi/30876 "2017-03-23T16:42:44Z")\
**Showing post:** 2
**Author:** ![nrobinson2000](https://sea2.discourse-cdn.com/flex026/user_avatar/community.particle.io/nrobinson2000/32/15624_2.png) [@nrobinson2000](https://community.particle.io/u/nrobinson2000)\
**Post date:** [March 23, 2017, 5:59pm UTC](https://community.particle.io/t/unable-to-use-usbserial-for-raspberrypi/30876/2 "2017-03-23T17:59:39Z")
ping @jvanier
Hi @craigmac, as far as I am aware this is a highly desired feature that is still under development. This has been discussed on this thread previously.
> [@Trouble Accessing Pi's RX and TX With Serial1](https://community.particle.io/t/trouble-accessing-pis-rx-and-tx-with-serial1/27621):
> Has anyone been able to successfully connect to RX and TX GPIO Pins on the RPI3 using particle-agent? I have a sensor that is connected to rx tx on the RPI but it appears that Serial1 never becomes available to my code. Been trying for two days now! Any suggestions would be greatly appreciated. int incomingByte = 0; void setup() { Serial.begin(115200); Serial1.begin(115200); Serial.println(“Starting…”); } void loop() { // send data only when you receive data: if (Serial1.available() \> …
I have also tried to use the serial pins on the gpio with no success in Particle firmware whatsoever.
> [@Tutorial: Enable GPIO Serial on RPi 3](https://community.particle.io/t/tutorial-enable-gpio-serial-on-rpi-3/30194):
> Hello everyone. [Today I found a very nice tutorial to enable UART (GPIO) serial on Raspberry Pi 3 and Pi Zero W.][1] To summarize, here are the commands I did to enable serial (/dev/ttyS0) on my Raspberry Pi 3: $ sudo -s $ echo "enable\_uart=1" \>\> /boot/config.txt $ systemctl stop serial-getty@ttyS0.service $ systemctl disable serial-getty@ttyS0.service $ nano /boot/cmdline.txt #Remove console=serial0,115200 After a reboot you should be able to use /dev/ttyS0 Quick test: $ sudo apt install…
_[View the full topic](https://community.particle.io/t/unable-to-use-usbserial-for-raspberrypi/30876)._
