I’m having troubles signing into my Particle account when I use Particle Dev on my Mac (Sierra 10.12.6).
I enter correct username and password and press “Log in”, the dialog closes but I’m still not signed in. In the down left corner of the screen I can still see “Click to log in to Particle Cloud…” and my Flash and Compile buttons are disabled.
There was an error reading /Users/bogdan/.particle/particle.config.json: Error: EACCES: permission denied, open '/Users/bogdan/.particle/particle.config.json'
at Object.fs.openSync (fs.js:558:18)
at Object.module.(anonymous function) [as openSync] (ELECTRON_ASAR.js:173:20)
at Object.fs.readFileSync (fs.js:468:33)
at Object.fs.readFileSync (ELECTRON_ASAR.js:506:29)
at Settings.loadOverrides (/Users/bogdan/.atom/packages/particle-dev-profiles/node_modules/particle-commands/dist/lib/settings.js:145:37)
at Object.buildSettings (/Users/bogdan/.atom/packages/particle-dev-profiles/node_modules/particle-commands/dist/lib/settings.js:403:12)
at ProfileManager._reloadSettings (/Users/bogdan/.atom/packages/particle-dev-profiles/src/profile-manager.js:349:57)
at ProfileManager.set (/Users/bogdan/.atom/packages/particle-dev-profiles/src/profile-manager.js:86:15)
at ProfileManager.set (/Users/bogdan/.atom/packages/particle-dev-profiles/src/profile-manager.js:232:8)
at /Users/bogdan/.atom/packages/particle-dev/lib/views/login-view.js:176:37
at tryCatchReject (/Users/bogdan/.atom/packages/particle-dev-profiles/node_modules/when/lib/makePromise.js:845:30)
at runContinuation1 (/Users/bogdan/.atom/packages/particle-dev-profiles/node_modules/when/lib/makePromise.js:804:4)
at Fulfilled.when (/Users/bogdan/.atom/packages/particle-dev-profiles/node_modules/when/lib/makePromise.js:592:4)
at Pending.run (/Users/bogdan/.atom/packages/particle-dev-profiles/node_modules/when/lib/makePromise.js:483:13)
at Scheduler._drain (/Users/bogdan/.atom/packages/particle-dev-profiles/node_modules/when/lib/Scheduler.js:62:19)
at Scheduler.drain (/Users/bogdan/.atom/packages/particle-dev-profiles/node_modules/when/lib/Scheduler.js:27:9)
at _combinedTickCallback (internal/process/next_tick.js:67:7)
at process._tickCallback (internal/process/next_tick.js:98:9)
