# Ultrathin 16x32 Red LED Matrix Panel
**URL:** <https://community.particle.io/t/ultrathin-16x32-red-led-matrix-panel/22995>\
**Category:** Libraries\
**Created:** [May 18, 2016, 7:09pm UTC](https://community.particle.io/t/ultrathin-16x32-red-led-matrix-panel/22995 "2016-05-18T19:09:52Z")\
**Showing post:** 2
**Post date:** [May 19, 2016, 6:15am UTC](https://community.particle.io/t/ultrathin-16x32-red-led-matrix-panel/22995/2 "2016-05-19T06:15:26Z")
The control logic seems to be similar to the ones used in the RGBMatrix library on Build which is also used in the RGBPongClock project
> [@Maker Faire RGBPongClock](https://community.particle.io/t/maker-faire-rgbpongclock/11813):
> UPDATE! I have finished a PCB for the RGB Pong Clock (or any other project using an RGB Matrix panel) and have sent it off for a quick run. It works with both the Core and the Photon and is designed to attach to the back of the panel. Once it is tested, I’ll be making it available to everyone. Here is a peek at the top of the board (sorry for the small size): [image] One of the projects I brought for Maker Faire in San Francisco is the RGBPongClock and I wanted to share the code with ever…
_[View the full topic](https://community.particle.io/t/ultrathin-16x32-red-led-matrix-panel/22995)._
