I had hooked up a pair of photons in this way and had results. But now that I’m using Argons, nothing appears to be getting printed to the SerialPort. Is there some change to I2C between Gen2 and Gen3?
I set up a pair of photons on a breadboard with this code and it worked fine. So it must have been an issue with the setup I had the argons in, likely a poor choice of pullup resistors. I’ll mark this concluded.
So I was able to get everything working as expected using Wire1 and pullup resistors. But the buffer size was 32 bytes and I’ll need more. I had previously used the following code to increase buffer size per the documentation but this didn’t seem to work on Wire1 on the Argons:
