Tutorial: Installing DFU-Driver on Windows [24 Feb 2015]
#34
@Werdna, I suggest you move the win32-mingw32 directory to the root of the drive and use that path instead.
#35
Wow. That worked like a miracle!
#36
@kennethlimcp, How do I update my current rev 0.7 DFU to 0.8? I downloaded the “dfu-util-0.8-binaries.tar.xz” binary but I’m not sure where or what I’m suppose to do with this file to update the DFU.
Any help will be much appreciated.
#37
@wesner0019, the file is actually an archive (like zip) file. What OS are you running on?
#38
@peekay123, windows 7
#39
@wesner0019, if you have winzip or 7zip or winrar, you should be able to right-click on the file and open it as an archive. If so, open the .tar file which is also an archive. Once open, open the directory you will see (dfu-util-0.8-binaries) and you will see the win32-mingw32 directory. The contents of that directory need to replace the ones in the directory on your PC.
#40
@peekay123, got it, working now, thanks!
#41
I tried for hours to get this to work on my windows7 machine. The dfu-util would never see the core. I finally read on another post that the dfu-util doesn’t like usb3 ports. I switched to a usb2 port and volia it works.
If dfu-util doesn’t see it, change it to a usb2 Port (usb3 didn’t work for me)
#45
what do you mean exactly mean by
I did all the above but I can’t find dfu-util.exe and when I write dfu-util in cmd I get:
‘dfu-util’ is not recognized as an internal or external command…
What is the problem?
#46
@mohmhus, Windows has an application search path. Open a CMD prompt and type “path” and you will see what your present windows search path is. For dfu-util to run from any directory, windows needs to find it. It does this by looking in the search path. You need to add the directory where you put the dfu-util.exe (and supporting files) to the path.
You can find help on doing that here or by googling “windows add to path” for example.
#47
If you look at the end of the tutorial, i have already provided a link on how to do that :wink:
#48
Thank you very much
The problem was that I didn’t know what a .tar file is :joy:
#49
Hello,
Is it working for Photon?
Thank you
#50
Yes.
#51
Thank you. I have tried it and no problem.
#52
I tried to follow this step by step got the dll installed. then i hit this line. I did a search on my PC i don’t have dfu-util.exe was that application supposed to install that as well?
I managed to get my photon stuck in safe mode was trying flash tinker to it. Ended up resetting it using my phone. Let me know how to get this to work because being able to flash code from my pc instead of the web interface will be useful seeing as the web interface doesn’t have any form for source control.
Linda
#53
Did you download dfu-util from the provided link, unpacked it and placed somewhere on your harddrive?
Or find it at the project home
http://dfu-util.sourceforge.net/releases/
#54
For Windows, this might be interesting as well :wink:
#55
I use CLI so it is installed. However it wouldn’t let me flash anything with out DFU-UTIL which i did a search on my pc and doesn’t exist.
I ran that drive program which i would assume would install the DFU-UTIL driver. Seams i missed where to get the DFU-UTIL from.
I will try this again the next time I manage to lock my photon in safemode.
#56
That installer should also install DFU Util for you, hence the suggestion. It really does make things easier.
There’s also this guide that should tell you how to get DFU Util going manually:
