#include <SdFat.h>
#include <Adafruit_DHT_Particle.h>
#include "SdFat.h"
// Example testing sketch for various DHT humidity/temperature sensors
// Written by ladyada, public domain
#define DHTPIN D2 // what pin we're connected to
// Uncomment whatever type you're using!
#define DHTTYPE DHT11 // DHT 11
//#define DHTTYPE DHT22 // DHT 22 (AM2302)
//#define DHTTYPE DHT21 // DHT 21 (AM2301)
// Connect pin 1 (on the left) of the sensor to +5V
// Connect pin 2 of the sensor to whatever your DHTPIN is
// Connect pin 4 (on the right) of the sensor to GROUND
// Connect a 10K resistor from pin 2 (data) to pin 1 (power) of the sensor
DHT dht(DHTPIN, DHTTYPE);
// Pick an SPI configuration.
// See SPI configuration section below (comments are for photon).
#define SPI_CONFIGURATION 0
// Setup SPI configuration.
#if SPI_CONFIGURATION == 0
// Primary SPI with DMA
// SCK => A3, MISO => A4, MOSI => A5, SS => A2 (default)
SdFat sd;
const uint8_t chipSelect = SS;
#elif SPI_CONFIGURATION == 1
// Secondary SPI with DMA
// SCK => D4, MISO => D3, MOSI => D2, SS => D1
SdFat sd(1);
const uint8_t chipSelect = D1;
#elif SPI_CONFIGURATION == 2
// Primary SPI with Arduino SPI library style byte I/O.
SdFatLibSpi sd;
#elif SPI_CONFIGURATION == 3
// Software SPI. Use any digital pins.
// MISO => D5, MOSI => D6, SCK => D7, SS => D0
SdFatSoftSpi<D5, D6, D7> sd;
const uint8_t chipSelect = D0;
#endif // SPI_CONFIGURATION
File myFile;
int loopCount;
float h = dht.getHumidity()/100;
// Read temperature as Celsius
float t = dht.getTempCelcius()/10;
// Read temperature as Farenheit
float f = dht.getTempFarenheit();
Serial.println("DHT11 test!");
Particle.publish("state", "DHTxx test start");
dht.begin();
loopCount = 0;
delay(2000);
while (!Serial) {
SysCall::yield();
Serial.println("Type any character to start");
while (Serial.read() <= 0) {
SysCall::yield();
// Initialize SdFat or print a detailed error message and halt
// Use full speed like the native library.
// Change to SPI_FULL_SPEED for more performance.
if (!sd.begin(chipSelect, SPI_FULL_SPEED)) {
sd.initErrorHalt();
// open the file for write at end like the "Native SD library"
if (!myFile.open("test.txt", O_RDWR | O_CREAT | O_AT_END)) {
sd.errorHalt("opening test.txt for write failed");
// if the file opened okay, write to it:
Serial.print("Writing to test.txt...");
myFile.println("Humid in %:");
myFile.println(h);
myFile.println("Temp in *C:");
myFile.println(t);
myFile.printf("fileSize: %d\n", myFile.fileSize());
// close the file:
myFile.close();
Serial.println("done.");
// re-open the file for reading:
if (!myFile.open("test.txt", O_READ)) {
sd.errorHalt("opening test.txt for read failed");
Serial.println("test.txt content:");
// read from the file until there's nothing else in it:
int data;
while ((data = myFile.read()) >= 0) {
Serial.write(data);
// close the file:
myFile.close();
// Wait a few seconds between measurements.
// delay(2000);
// Reading temperature or humidity takes about 250 milliseconds!
// Sensor readings may also be up to 2 seconds 'old' (its a
// very slow sensor)
float h = dht.getHumidity();
float t = dht.getTempCelcius();
// Check if any reads failed and exit early (to try again).
if (isnan(h) || isnan(t) || isnan(f)) {
Serial.println("Failed to read from DHT sensor!");
return;
// Compute heat index
// Must send in temp in Fahrenheit!
float hi = dht.getHeatIndex();
float dp = dht.getDewPoint();
float k = dht.getTempKelvin();
Serial.print("Humid: ");
Serial.print(h);
Serial.print("% - ");
Serial.print("Temp: ");
Serial.print(t);
Serial.print("*C ");
Serial.print(f);
Serial.print("*F ");
Serial.print(k);
Serial.print("*K - ");
Serial.print("DewP: ");
Serial.print(dp);
Serial.print("*C - ");
Serial.print("HeatI: ");
Serial.print(hi);
Serial.println("*C");
Serial.println(Time.timeStr());
String timeStamp = Time.timeStr();
Particle.publish("readings", String::format("{\"Hum(\%)\": %4.2f, \"Temp(°C)\": %4.2f, \"DP(°C)\": %4.2f, \"HI(°C)\": %4.2f}", h, t, dp, hi));
delay(10000);
loopCount++;
if(loopCount >= 6){
Particle.publish("state", "Going to sleep for 5 minutes");
delay(1000);
System.sleep(SLEEP_MODE_DEEP, 300);
@Trigga, you need to include more details like:
- DeviceOS version
- What versions of the libraries are you using
- What is the device doing that you’re having problems with
We can’t help you otherwise!
This topic was automatically closed 60 days after the last reply. New replies are no longer allowed.
