I am fairly new to coding and particle devices. In my code:
powerCheck.setup();
Particle.variable(“Power”, powerCheck.getHasPower);
if (millis() - lastCheck > 2000) {
lastCheck = millis();
char buffer[256];
snprintf(buffer, sizeof(buffer), "hasPower=%d hasBattery=%d isCharging=%d",
powerCheck.getHasPower(), powerCheck.getHasBattery(), powerCheck.getIsCharging());
if (strcmp(lastStatus, buffer) != 0) {
strcpy(lastStatus, buffer);
Particle.publish("battery", buffer, PRIVATE);
I get error 137:51: invalid use of non-static member function
I am trying to add in that I check power status via the api. I have bolded the code that i added. If I remove it it works fine. But I am really looking to call this function via an api call.
