Hello,
For the past few days, my Photon 1 devices have been having trouble connecting to the Particle Cloud. They alternate several times between cycles of sky-blue flashes and three orange flashes. Eventually, the connection is established in most cases.
I’ve tried repairing and regenerating the keys using Particle Keys Doctor, but nothing has changed.
Is anyone else experiencing this same issue and do you have a solution?
Thanks in advance.
Best regards,
Blinking cyan followed by 3 orange blinks is Wi-Fi network is reachable, but the Particle cloud is not.
The most common reason for this is that a firewall on your network is blocking access to the Particle cloud, either by blocking the TCP CoAP connection, or DNS is blocking access to the cloud server IP adddress.
See cloud services and firewalls for more information.
Getting a debug log with web device doctor may provide additional clues.
