I’m trying to get started on an app that will control some simple DC motors with an Argon. It appears the Adafruit DC Motor + Stepper FeatherWing Add-on For All Feather Boards would be a good fit. While I wait for delivery of that board, I thought I’d get started on the application. Unfortunately I’m having an issue with multiple definitions and I’ve tried numerous things to resolve the issue, but without success. I am using Dev (VSC) for development as usual.
Here’s my very simple app:
* Project witchV1
* Description: Halloween witch manequin automation
* Author: Tom Morrison
* Date: April 2021->
#include "application.h"
#include "Adafruit-MotorShield-V2.h"
#include "Adafruit_PWMServoDriver.h"
Adafruit_MotorShield AFMS = Adafruit_MotorShield();
Adafruit_DCMotor *head = AFMS.getMotor(1);
Adafruit_DCMotor *mouth = AFMS.getMotor(2);
AFMS.begin();
head->setSpeed(100); //0=stopped --> 255=full speed
mouth->setSpeed(100); //same as above
// Let's just get something moving to test the motor connections and directions.
head->run(FORWARD);
delay(1000);
head->run(BACKWARD);
head->run(RELEASE);
mouth->run(FORWARD);
delay(1000);
mouth->run(BACKWARD);
mouth->run(RELEASE);
Here’s an example of the errors I continue to get:
:::: COMPILING APPLICATION
Creating /Users/tom/Documents/Particle/Projects-Home/witchV1/target/2.0.1/argon/platform_user_ram.ld ...
/Users/tom/.particle/toolchains/gcc-arm/9.2.1/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld: ../../../build/target/user/platform-12-m/witchV1//libuser.a(Adafruit_PWMServoDriver.o): in function `Adafruit_PWMServoDriver::Adafruit_PWMServoDriver(unsigned char)':
/Users/tom/.particle/toolchains/deviceOS/2.0.1/user/../wiring/inc/spark_wiring_i2c.h:126: multiple definition of `Adafruit_PWMServoDriver::Adafruit_PWMServoDriver(unsigned char)'; ../../../build/target/user/platform-12-m/witchV1//libuser.a(Adafruit_PWMServoDriver.o):/Users/tom/Documents/Particle/Projects-Home/witchV1/lib/Adafruit-MotorShield-V2/src/Adafruit_PWMServoDriver.cpp:23: first defined here
/Users/tom/.particle/toolchains/gcc-arm/9.2.1/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld: ../../../build/target/user/platform-12-m/witchV1//libuser.a(Adafruit_PWMServoDriver.o): in function `Adafruit_PWMServoDriver::setPWM(unsigned char, unsigned short, unsigned short)':
/Users/tom/.particle/toolchains/deviceOS/2.0.1/user/../wiring/inc/spark_wiring_i2c.h:126: multiple definition of `Adafruit_PWMServoDriver::setPWM(unsigned char, unsigned short, unsigned short)'; ../../../build/target/user/platform-12-m/witchV1//libuser.a(Adafruit_PWMServoDriver.o):/Users/tom/Documents/Particle/Projects-Home/witchV1/lib/Adafruit-MotorShield-V2/src/Adafruit_PWMServoDriver.cpp:59: first defined here
/Users/tom/.particle/toolchains/gcc-arm/9.2.1/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld: ../../../build/target/user/platform-12-m/witchV1//libuser.a(Adafruit_PWMServoDriver.o): in function `Adafruit_PWMServoDriver::read8(unsigned char)':
/Users/tom/Documents/Particle/Projects-Home/witchV1/lib/Adafruit_PWMServoDriver/src/Adafruit_PWMServoDriver.cpp:127: multiple definition of `Adafruit_PWMServoDriver::read8(unsigned char)'; ../../../build/target/user/platform-12-m/witchV1//libuser.a(Adafruit_PWMServoDriver.o):/Users/tom/Documents/Particle/Projects-Home/witchV1/lib/Adafruit-MotorShield-V2/src/Adafruit_PWMServoDriver.cpp:73: first defined here
/Users/tom/.particle/toolchains/gcc-arm/9.2.1/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld: ../../../build/target/user/platform-12-m/witchV1//libuser.a(Adafruit_PWMServoDriver.o): in function `Adafruit_PWMServoDriver::write8(unsigned char, unsigned char)':
/Users/tom/Documents/Particle/Projects-Home/witchV1/lib/Adafruit_PWMServoDriver/src/Adafruit_PWMServoDriver.cpp:136: multiple definition of `Adafruit_PWMServoDriver::write8(unsigned char, unsigned char)'; ../../../build/target/user/platform-12-m/witchV1//libuser.a(Adafruit_PWMServoDriver.o):/Users/tom/Documents/Particle/Projects-Home/witchV1/lib/Adafruit-MotorShield-V2/src/Adafruit_PWMServoDriver.cpp:85: first defined here
/Users/tom/.particle/toolchains/gcc-arm/9.2.1/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld: ../../../build/target/user/platform-12-m/witchV1//libuser.a(Adafruit_PWMServoDriver.o): in function `Adafruit_PWMServoDriver::reset()':
/Users/tom/Documents/Particle/Projects-Home/witchV1/lib/Adafruit_PWMServoDriver/src/Adafruit_PWMServoDriver.cpp:50: multiple definition of `Adafruit_PWMServoDriver::reset()'; ../../../build/target/user/platform-12-m/witchV1//libuser.a(Adafruit_PWMServoDriver.o):/Users/tom/Documents/Particle/Projects-Home/witchV1/lib/Adafruit-MotorShield-V2/src/Adafruit_PWMServoDriver.cpp:33: first defined here
/Users/tom/.particle/toolchains/gcc-arm/9.2.1/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld: ../../../build/target/user/platform-12-m/witchV1//libuser.a(Adafruit_PWMServoDriver.o): in function `Adafruit_PWMServoDriver::begin()':
/Users/tom/Documents/Particle/Projects-Home/witchV1/lib/Adafruit_PWMServoDriver/src/Adafruit_PWMServoDriver.cpp:43: multiple definition of `Adafruit_PWMServoDriver::begin()'; ../../../build/target/user/platform-12-m/witchV1//libuser.a(Adafruit_PWMServoDriver.o):/Users/tom/Documents/Particle/Projects-Home/witchV1/lib/Adafruit-MotorShield-V2/src/Adafruit_PWMServoDriver.cpp:26: first defined here
/Users/tom/.particle/toolchains/gcc-arm/9.2.1/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld: ../../../build/target/user/platform-12-m/witchV1//libuser.a(Adafruit_PWMServoDriver.o): in function `Adafruit_PWMServoDriver::setPWMFreq(float)':
/Users/tom/Documents/Particle/Projects-Home/witchV1/lib/Adafruit_PWMServoDriver/src/Adafruit_PWMServoDriver.cpp:53: multiple definition of `Adafruit_PWMServoDriver::setPWMFreq(float)'; ../../../build/target/user/platform-12-m/witchV1//libuser.a(Adafruit_PWMServoDriver.o):/Users/tom/Documents/Particle/Projects-Home/witchV1/lib/Adafruit-MotorShield-V2/src/Adafruit_PWMServoDriver.cpp:36: first defined here
make[2]: *** [/Users/tom/Documents/Particle/Projects-Home/witchV1/target/2.0.1/argon/witchV1.elf] Error 1
make[1]: *** [modules/argon/user-part] Error 2
make: *** [compile-user] Error 2
The terminal process "/bin/bash '-c', 'make -f '/Users/tom/.particle/toolchains/buildscripts/1.10.0/Makefile' compile-user -s'" terminated with exit code: 2.
Press any key to close the terminal.
I even tried compiling via Build, but with the same duplicate errors. I did notice the Adafruit-MotorShield-V2 library includes the Adafruit_PWMServoDriver.h and .cpp files. I tried removing those. I also tried not including those in the app itself, assuming the motor lib included them. I’m perplexed and perhaps too tired and “can’t see the forest for the trees”.
Any suggestions would be greatly appreciated. I’ve just never run across this in the past.
