Tracker One: three Sep/Oct 2026 units never receive CAN frames, identical firmware works on an earlier unit
We run Tracker One units reading a Kubota engine's J1939 bus (250 kbps) via the onboard MCP25625 in listen-only mode.
Three units received Sep/Oct 2026 never receive a single CAN frame. A unit from the same serial run, same Device OS
6.4.1, same application firmware, reads the same bus fine.
Device Serial ICCID (last 8) Reads CAN?
4RC2TW P031AD6304RC2TW 71903478 No
BW9TKC P031AD630BW9TKC 71901464 No
UXKWJY P031AD630UXKWJY 71903429 No (one frame, once)
JC7K5T P031AD630JC7K5T 76634086 Yes, 60k+ frames
What we have ruled out:
  • Not the bus or wiring. A known-good Tracker One from our fleet (Device OS 5.8.0) on the same cable, same
    trailer, reads engine data within two minutes. Two of the failing units were tried on that same cable and read
    nothing.
  • Not a dead CAN controller. On a failing unit the USB log shows CAN initialization succeeded from the MCP25625
    at 2.7 s after boot, then 150 s with zero frames, engine running. Our driver inits with MCP_20MHZ at 250 kbps, sets
    MCP_MODE_LISTENONLY, and reads only when CAN_INT (P1.09) goes low.
  • Not software alone. Device OS and app firmware are identical on the working unit.
The only pattern we can see: the failing units share ICCID group ...7190xxxx, the working one is ...7663xxxx, which
suggests a different production lot.
Questions:
  1. Did anything change on Tracker One hardware for serials P031AD630... shipped Sep-Oct 2026, specifically the
    MCP25625 oscillator frequency or the CAN_INT / CAN_RST / CAN_STBY / CAN_PWR mapping?
  2. Is there a way to read a Tracker One's hardware revision from the Console or cloud API? The device page doesn't
    show one.
  3. Any known CAN-receive issue on units from this window?
Happy to run any test on a failing unit; we have USB access to all three. Startup log excerpt below.
0000001170 [ModelGauge] INFO: load model successfully
0000002666 [app] INFO: CAN initialization succeeded
0000005219 [app] INFO: Horizon session_id=10 reset_reason=140(user)
0000005667 [app] INFO: HorizonTelemetry: pub ok=1 uptime=5 ... engOn=0 pumpOn=0
... 150 s of GPS lines only, zero CAN frames, engine at 1100 rpm ...
There have been no changes to the Tracker One. And comparing the last two devices, both came off the assembly line on 2026-07-21, so the hardware would be the same version.
The failing unit also passed the CAN loopback test on the manufacturing line. Though if I recall correctly, loopback only tests the controller, not the transceiver on the MCP25625.
It's not clear why the failing ones are not working, but I don't think the SIM ICCID is necessarily significant.
