Hi there,
While trying to compile using the online IDE I get the following message:
/usr/local/gcc-arm-embedded-gcc-arm-none-eabi-4_8-2014q2-20140609-linux-tar-bz2/bin/../lib/gcc/arm-none-eabi/4.8.4/../../../../arm-none-eabi/bin/ld: 0215818fdfba86bccfbd2ba08a314bb50ee8a862fab96a8c042e7e04f1ef.elf section `.text' will not fit in region `APP_FLASH'
/usr/local/gcc-arm-embedded-gcc-arm-none-eabi-4_8-2014q2-20140609-linux-tar-bz2/bin/../lib/gcc/arm-none-eabi/4.8.4/../../../../arm-none-eabi/bin/ld: region `APP_FLASH' overflowed by 71472 bytes
make[1]: *** [0215818fdfba86bccfbd2ba08a314bb50ee8a862fab96a8c042e7e04f1ef.elf] Error 1
make: *** [main] Error 2
What is the common cause to this issue? Is it simply due to the size of the code, or some of the data structures?
Thanks.
