System.on button click for external button
Good Morning.
I was wondering if the below button click handler could work on external buttons. It is working very well on Argon mode button.
 System.on(button_click, systemEventHandler);// Set up button event handler
void systemEventHandler(system_event_t event, int duration, void* )
   //button event handler for enrollment
    if(event == button_click) {
        if(isBeaconEnrollModeOn()){
            setBeaconEnrollModeOff();
        } else {
            setBeaconEnrollModeOn();
            Serial.println("Beacon Enrollment on\n");
// Check if enrolling is on
bool isBeaconEnrollModeOn() {
    return (enrollBeacons);
// Set enrolling on
void setBeaconEnrollModeOn() {
      enrollBeacons=1;// enrollemnt is on
// Set enrolling off
void setBeaconEnrollModeOff() {
  digitalWrite(D7,HIGH);
  enrollBeacons = 0;// enrollment is off
I want to be able to use it on my external button if I change “event” and “Button_click”
to LOAD and buttonLOAD (which is my external button)
const int LOAD = D3;
int buttonLOAD;//holds button load value
pinMode(LOAD, INPUT);//output for triggered led
thanks
No, the internal button handler cannot be used for external buttons.
There are many libraries to handle debouncing of external buttons. I often use the Debounce library in the community libraries.
