Hi Suprazz,
I’m Frederic, living in France,
First of all, happy new year and all the best to you and all the readers of my reply!
I’m struggling for days to find a way to upload files to an external chip (W25Q64) using an FTP server.
It seems that you managed to do that.
I’m quite new with C++ code, and i’m moving forward on my projects doing test/error/test/error…so moving really slowly and i’m totally blocked today.
I can create the FTP server, and i can access to the Internal memory of my ESP32-S3.
I then use an FTP client (FileZilla) and i can drag and drop files. It works perfectly.
But what i would like to do is exactly the same, but with an external chip, connected to MISO/MOSI/SCK/CS to pins to my ESP32.
Do you think you can share your code so i can see how you managed that?
Thanks a million in advance for your time and skills,
Frederic.
@fepalmytho, this is a forum for Particle device users, which are based on different processors and firmware since they have a DeviceOS. You should look on Espressif or Arduino ESP32 Core forums (depending on how you are creating your firmware) for solutions.
Hi, thanks a lot for your prompt answer.
I gave a try on your forum, as i did’nt find any solution on the other specific forums.
Thanks anyway,
Regards,
Frédéric.
