This is an old thread but thought I’d add my code in case someone else runs into the same issue. It took me a few hours to figure out. Maybe someone will find it useful and save them time.
#prior code omitted from this post cleanliness
for msg in messages:
#Get the message event type. This is the Publish Event name.
event = str(msg.event)
#Only add events to SQL that have the event name of "Stat"
if event == 'Stat':
#use str and JSON.Loads to decifer string/JSON object from Particle into a Python Dictionary
data = str(msg.data)
msgDict = json.loads(data)
dataDict = json.loads(msgDict["data"])
msgDict.update({'data': dataDict})
#Now that the message from Particle is a Pyhton Dictionary, access info within it like this:
DEVICE_ID=msgDict["coreid"],
TempF=msgDict['data']['TempF']
#Do whatever you want with the data now.
