I’m having an issue with a simple program to test how to programmatically go into connected mode after starting up in semi-automatic mode. The attached program simply remains in WiFi off (breathing white). I know I’m likely missing something simple here. Guidance would be greatly appreciated.
SYSTEM_MODE(SEMI_AUTOMATIC)
SYSTEM_THREAD(ENABLED)
int i=0;
int led7 = D7;
pinMode(led7, OUTPUT);
int i = i+1;
digitalWrite(led7,HIGH);
//Serial.printlnf("System version: %s", System.version().c_str());
delay(1000);
digitalWrite(led7,LOW);
//Serial.println(WiFi.localIP());
//Serial.println(WiFi.macAddress());
delay(1000);
if (i>10) {
if (!Particle.connected()) {
flashLED();
WiFi.on();
WiFi.connect();
Particle.connect();
flashLED();
void flashLED() {
for (int i = 1;i<6;i++){
delay(100);
delay(100);
