I’m having trouble getting my spark core to flash correctly. I can use the CLI to flash back to tinker, but when I try to flash an application that I’ve used in the past, it doesn’t work and seems to get stuck in reboot loop. This happens when I flash using USB or OTA.
After doing the magenta update it will go
- flashing green
- lashing cyan
- short yellow a few times,
- back to flashing cyan
- back to flash green and loop this sequence again
