# Strategies to upload new firmware remotely when an Electron has to go into deep sleep
**URL:** <https://community.particle.io/t/strategies-to-upload-new-firmware-remotely-when-an-electron-has-to-go-into-deep-sleep/47073>\
**Category:** General\
**Tags:** electron\
**Created:** [January 17, 2019, 9:58am UTC](https://community.particle.io/t/strategies-to-upload-new-firmware-remotely-when-an-electron-has-to-go-into-deep-sleep/47073 "2019-01-17T09:58:48Z")\
**Showing post:** 3
**Author:** ![chuank](https://sea2.discourse-cdn.com/flex026/user_avatar/community.particle.io/chuank/32/3617_2.png) [@chuank](https://community.particle.io/u/chuank)\
**Post date:** [January 17, 2019, 8:38pm UTC](https://community.particle.io/t/strategies-to-upload-new-firmware-remotely-when-an-electron-has-to-go-into-deep-sleep/47073/3 "2019-01-17T20:38:42Z")
Thanks @Rftop!
The setup I have uses deep sleep, unfortunately – it's running solar off a 2500mah lipo. It's still an excellent link, never realised a wake on cellular is possible with the Electron.
I'll keep poking around to see what other options there might be to ensure a firmware update request will always get to the Electron when it wakes.
> [@WakeOn RI in SLEEP\_NETWORK\_STANDBY?](https://community.particle.io/t/wakeon-ri-in-sleep-network-standby/43756/3):
> You can’t wake from SLEEP\_MODE\_DEEP from a pin other than WKP, so you can’t wake on RI\_UC
_[View the full topic](https://community.particle.io/t/strategies-to-upload-new-firmware-remotely-when-an-electron-has-to-go-into-deep-sleep/47073)._
