# Strange behaviour on the Web IDE \[SOLVED\]
**URL:** <https://community.particle.io/t/strange-behaviour-on-the-web-ide-solved/2729>\
**Created:** [February 9, 2014, 8:25pm UTC](https://community.particle.io/t/strange-behaviour-on-the-web-ide-solved/2729 "2014-02-09T20:25:32Z")\
**Showing post:** 4
**Author:** ![jgoggins](https://sea2.discourse-cdn.com/flex026/user_avatar/community.particle.io/jgoggins/32/20654_2.png) [@jgoggins](https://community.particle.io/u/jgoggins)\
**Post date:** [February 10, 2014, 10:06pm UTC](https://community.particle.io/t/strange-behaviour-on-the-web-ide-solved/2729/4 "2014-02-10T22:06:15Z")
Hey @Dom @binaryfrost , just an FYI, we just deployed a fix for this:
> **[Web IDE Bug: New multiple files feature is duplicating things!](https://community.particle.io/t/web-ide-bug-new-multiple-files-feature-is-duplicating-things/2692/10)**
> FEATURE REQUEST - When you create multi-file “composite” the files are only known to each other. If you try to reference one of the files in another file outside that composite, that file is not seen. So if you have one piece of code working...
Thanks for reporting this issue and sorry for any troubles it make have caused.
_[View the full topic](https://community.particle.io/t/strange-behaviour-on-the-web-ide-solved/2729)._
