I am new to this programming stuff, so I just wonder if anybody can point me out on some existing projects as close as possible with what I need :
- 1.st ppotentiometer will be used just simply to set desired speed (0-100RPM) (say I will set 10rpm)
- With 2nd. potentiometer I need to set RATIO (say 10K value will be split to 7K and 3K) and with this ratio I need to split the TOTAL speed (set 10RPM ) between 2stepper motors,…
… so 1.stepper motor will have speed of 7RPM and 2nd motor will have 3RPM…
Direction will be always only in one direction…dont ned to change that.
Any ideas?
