Hi All,
I’ve just found that the Electron’s cellular modem looks like it will handle SSL over TCP if you load certificates with the USECMNG command. You can find them in this manual https://www.u-blox.com/sites/default/files/u-blox-CEL_ATCommands_(UBX-13002752).pdf
Before I embark on this further, I’m curious if anyone has experience with this?
@hwestbrook, the SARA module used on the Electron is not the version that supports onboard SSL unfortunately.
We use the U260 almost exclusively and it looks like the U260 supports this feature in u-blox’s data sheet https://www.u-blox.com/sites/default/files/SARA-U2_DataSheet_(UBX-13005287).pdf
Do you have information that contradicts that data sheet?
Unfortunately, there is no hardware SSL/TLS. Note that it’s only supported on the SARA-U260-03S. The Electron has a SARA-U260-00S-00 model. Same for U270.
manufacturer=u-blox
model=SARA-U260
firmware version=23.20
ordering code=SARA-U260-00S-00
From the AT command reference:
