In looking at spi_hal.c they have the following (see below).
There should never be a while condition like this inside a call. Should the SPI device fail it would lock up the rest of the code who called this from continuing. They should instead add another parameter to pass along a timeout value to the call. So when called if nothing returns after this timout value passed it can let the caller know it failed with say a -1 value.
uint16_t HAL_SPI_Send_Receive_Data(HAL_SPI_Interface spi, uint16_t data)
/* Wait for SPI1 Tx buffer empty */
while (SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_TXE) == RESET);
/* Send SPI1 data */
SPI_I2S_SendData(SPI1, data);
/* Wait for SPI1 data reception */
while (SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_RXNE) == RESET);
/* Read and return SPI1 received data */
return SPI_I2S_ReceiveData(SPI1);
