Looking at the power adapter that you sell, I am wondering if this is a UL listed product. We will be handing power adapters out to other companies for testing and we do not want to have liability issues be cause of faults adapters causing shocks of fires such as the cheap $2 chinese counterfeit apple adapters
Yes, the power supply is UL Listed. The certification number is printed on the device (E310745), and we received proof of confirmation from UL’s database before purchasing the units. You can also lookup the UL listing here:
@will Have you looked at the output signal with no load and full load? I’m curious about the quality of the power generated. Here is a good reference for what to look for on USB wall warts.
