I guess I’m at a loss as to why your Spark Core may be affecting your specific WiFi modem/hotspot device. Were you just running Tinker on the Spark Core when this happened? I would suspect on the b/g/n mixed mode. dedicated n won’t work.
Try this code and open a serial terminal and press W to connect your Core to WiFi and see if it resets your router on just that command alone. You can then also play with other commands… C to connect to the Spark Cloud. Then T to do some TCP Client file downloading. t to stop downloading. Disconnect from WiFi with w
#include "application.h"
SYSTEM_MODE(MANUAL);
void tcp_connect();
int f(String s);
TCPClient client;
bool doNotProcessMain = true;
uint32_t t = 0;
uint32_t t2 = 0;
// Make sure your Serial Terminal app is closed before powering your Core
Spark.function("f", f);
Spark.connect();
while(!Spark.connected()) {
Spark.process();
SPARK_WLAN_Loop();
pinMode(D7,OUTPUT);
while(doNotProcessMain) {
if (Serial.available()) {
int c = Serial.read();
switch (c) {
case 'C': Spark.connect(); break;
case 'c': Spark.disconnect(); break;
case 'W': WiFi.connect(); break;
case 'w': WiFi.disconnect(); break;
case 'T': tcp_connect(); break;
case 't': client.stop(); break;
case 'O': WiFi.on(); break;
case 'o': WiFi.off(); break;
case 'L': WiFi.listen(); break;
case 'x':
if(Spark.connected()) Serial.println("Connected");
else Serial.println("Not Connected");
break;
case 'm': doNotProcessMain = false; break;
case 's': SPARK_WLAN_Loop(); break;
case 'p': Spark.process(); break;
if (client.available())
char c = client.read();
Serial.print(c);
// Blink the D7 LED so we can see when user code is running
if(Spark.connected()) {
if (millis() - t2 > 50) {
t2 = millis();
digitalWrite(D7, !digitalRead(D7));
else
if (millis() - t2 > 200) {
t2 = millis();
if (millis() - t > 1000) {
Serial.println("calling Spark.process()");
Spark.process();
t = millis();
void tcp_connect() {
Serial.println("connecting...");
if (client.connect("www.textfiles.com", 80))
Serial.println("connected");
client.println("GET /100/ad.txt HTTP/1.0");
client.println("Host: www.textfiles.com");
client.println("Content-Length: 0");
client.println();
else
Serial.println("connection failed");
int f(String s) {
Serial.println("Spark.function running");
Serial.println(s);
return 0;
