Hey ScruffR do you think itโs because the delay should come before the sleep call? I was thinking maybe when the core wakes up it starts over at the beginning of the loop and not where the call left off. Iโll test this once Iโm home and if that fails I will test what you said to try.
Yes I definitely am using a core and you are 100% correct this issue is resolved. The core starts over again, so the sleep call needs to be at the end of the code.
