Hi all !
is it possible for the spark-io or johnny five to read/write serial data from spark core pins ?
Hi all !
The Core, or Photon, can read serial IO, as well as send it.
I want to use node.js to read that info and write it
It looks like the firmware counterpart to spark-io
, which is called voodoospark
, does support serial communications. However it looks like the spark-io
(by the creators of Johnny Five) may not support it yet. If you’d like that feature, you should open an issue on the spark-io
repository:
