# Spark Core + AccelStepper Library problems
**URL:** <https://community.particle.io/t/spark-core-accelstepper-library-problems/14702>\
**Category:** Libraries\
**Created:** [August 24, 2015, 8:09pm UTC](https://community.particle.io/t/spark-core-accelstepper-library-problems/14702 "2015-08-24T20:09:06Z")\
**Showing post:** 11
**Post date:** [August 26, 2015, 5:01am UTC](https://community.particle.io/t/spark-core-accelstepper-library-problems/14702/11 "2015-08-26T05:01:51Z")
There are several ways (more and less verbose) to connect and there are multiple threads that show how to code it.
One way is shown here
[Photon/P1 loop()/user code blocking in SEMI\_AUTOMATIC mode](http://community.particle.io/t/photon-p1-loop-user-code-blocking-in-semi-automatic-mode/14089/4)
For your purpose to only connect for OTA flashing, you might want to put the connection logic into a function and trigger that fn via a button.
_[View the full topic](https://community.particle.io/t/spark-core-accelstepper-library-problems/14702)._
