# Spark as stand alone server
**URL:** <https://community.particle.io/t/spark-as-stand-alone-server/4831>\
**Category:** General\
**Created:** [June 3, 2014, 11:33pm UTC](https://community.particle.io/t/spark-as-stand-alone-server/4831 "2014-06-03T23:33:46Z")\
**Showing post:** 5
**Author:** ![bko](https://sea2.discourse-cdn.com/flex026/user_avatar/community.particle.io/bko/32/20704_2.png) [@bko](https://community.particle.io/u/bko)\
**Post date:** [June 4, 2014, 11:37pm UTC](https://community.particle.io/t/spark-as-stand-alone-server/4831/5 "2014-06-04T23:37:45Z")
Hi @ecosta
You won’t need the Ethernet or dhcp classes or code–that is all built-in with Spark. You will need TCPServer, which is doc’ed here along with all the other methods and classes:
[http://docs.spark.io/firmware/#communication-tcpserver](http://docs.spark.io/firmware/#communication-tcpserver)
You should also look at
> **[Tiny WebServer code](https://community.particle.io/t/tiny-webserver-code/3297)**
> Continuing the discussion from Will there be a Spark Core II:
for an example.
_[View the full topic](https://community.particle.io/t/spark-as-stand-alone-server/4831)._
