Along with cpp
you can also use other language hints (e.g.html
, java
, …) and depending on whichever you use code highliting might reflect the actual types of expressions better than others.
If you don’t provide a hint to the rendering engine, the highlighting may look better for one statement but get confusing for another.
So it’s up to preference and as a rule of thumb, after submitting the post checking how it turned out should become a habit and if you are not satisfied, you can always edit/tweak your own posts to better reflect your intent.
For example
// with cpp
int i = 10;
Serial.printlnf("some literal with number %d", i);
if (someCondition == true)
someCondition = false;
or
// with text
int i = 10;
or
// without but due to the content the engine makes a good educated guess
// but you never know beforehand ;-)
int i = 10;
(note Serial
is now rendered differently than before with only one line provided)
I have now split this discussion off the original topic since it didn’t contribute to the original problem of
Electron reading digital pin state help request (novice)
