[solved] Undefined Reference error (linker error) when compiling from web IDE
Awesome stuff! @BDub @zach @ScruffR @mdma @michaelT
I verified and things work! IDE can get slow at times, especially when it comes to re-imports [Delete lib, add it again, some times empty the cache, bla, bla.]
The reason you couldn’t get the second example to build, is probably because it has a dependency with SparkJson library.
Now some real work begins. Thanks again!
that’s right.
tnx
