Hi everyone,
I’ve been experimenting with the System thread functionality, but have run into an issue.
Since System Threads are a beta feature, I’m guessing that’s a good thing
It seems enabling the new System Thread prevents multicast UDP messages from being received on the user thread.
I’ve pared my program down to a minimal test program below.
The test program listens to UDP multicast messages on 225.0.0.37:21928 and toggles the D7 LED every time it receives a message.
Without the System Thread, the LED switches as expected every time I send a message.
After enabling the system thread the LED doesn’t toggle any more.
This is on firmware 0.4.9.
I currently send the message from a cobbled-together java program, but intend on using ipMidi in the future, to control the Photon (and an Adafruit LED ring) via MIDI.
Background:
I’ve previously worked with System Modes (semi-automatic and manual), because I won’t always have internet/cloud access where I intend to use these (festival stages, with a wifi router I’ll bring myself).
However, even losing the local wifi connection suspends the user code (and thus my LED animations) while the Photon re-establishes the connection.
The System Thread solves this problem (the animation continues while reconnecting the wifi), but breaks my ability to control it via multicast.
I can’t have my cake and eat it too, it seems
I’ve searched here on the forums, but all similar issues with UDP multicast are from before the system threads existed.
None of the system thread topics mention UDP multicast, though some have problems with Particle functions/variables it seems
My apologies if I’ve overlooked anything.
Test program:
//SYSTEM_THREAD(ENABLED); // uncommenting this means multicast is never received below
UDP ipMidiUdp;
int ipMidiPort = 21928;
IPAddress ipMidiIp(225,0,0,37);
pinMode(led1, OUTPUT);
digitalWrite(led1, HIGH);
ipMidiUdp.begin(ipMidiPort);
ipMidiUdp.joinMulticast(ipMidiIp);
bool toggle = true;
int packetsize = ipMidiUdp.parsePacket();
if (packetsize > 0) { // never TRUE with System thread
toggle = !toggle;
digitalWrite(D7, toggle ? HIGH : LOW);
