Is there a way for me to update my Photon via the build ide? I know that you can update with dfu mode but I think updating via the build ide would be much more convenient.
Hmm, am I missing something?
The “flash” button top left of your Build window does … guess … flash your code OTA to your selected device.
Or are you looking for something else?
I just found the flash button. How do I flash the Photon via the build ide?
I’d guess the docs are available to you too
https://docs.particle.io/guide/getting-started/build/photon/#flashing-your-first-app
Have you tried, I don’t know… clicking it?
yes and nothing happened.
Then I’d highly suggest reading the docs that are mentioned.
Just got it to work! Thanks!
Great!
Might I suggest you try searching the docs next time? Answers often aren’t that hard to find if you’re willing to try.
