I built and flashed binary to Photon with CLI
Code gets uploaded ok and it runs for a short while - I get a few messages over into Particle console.
But afterwards Photon restarts and old code starts running - this code was previously uploaded via web base Particle Build.
The same thing is happening even if I try default tinker app (particle flash --usb tinker).
Only warning I am getting is: Invalid DFU suffix signature
This is the output of tinker flash command:
C:\>particle flash --usb tinker
Found DFU device 2b04:d006
checking file C:\Users\ZzZzZz\AppData\Roaming\npm\node_modules\particle-cli\bina
ries\photon_tinker.bin
spawning dfu-util -d 2b04:d006 -a 0 -i 0 -s 0x080A0000:leave -D C:\Users\ZzZzZz\
AppData\Roaming\npm\node_modules\particle-cli\binaries\photon_tinker.bin
dfu-util 0.8
ID 2b04:d006
Claiming USB DFU Interface...
dfuIDLE, continuing
Downloading to address = 0x080a0000, size = 3952
Download [=========================] 100% 3952 bytes
Download done.
File downloaded successfully
Flash success!
