Okay, here’s an interesting update. It would appear that if I put similar code in the main loop() that I get a mixed result; timer.isActive()
doesn’t work the first time through the loop, but timer.isActive()
does work the second time through the loop. It would appear that timer.isActive()
only switches to true in between loops.
Here is my code:
#include "Particle.h"
SYSTEM_MODE(SEMI_AUTOMATIC);
void timerCallback(); //Forward declaration of timer callback function
Timer myTimer(1000, timerCallback); //Declare/define the software timer
void timerCallback(){
myTimer.stopFromISR();
digitalWrite(D7, HIGH);
void setup(){
//Start the serial monitor
Serial.begin(9600);
pinMode(D7, OUTPUT);
digitalWrite(D7, LOW);
//Wait for user to enter a character into the serial monitor before continuing
while(!Serial.available()){};
Serial.println("Detected your keystroke!");
void loop(){
Serial.println("Configuring the timer...");
//Configure the timer
myTimer.changePeriod(5000);
myTimer.reset();
myTimer.start();
Serial.println("Now loop until the timer is no longer active");
//Loop until the myTimer.isActive() is false
boolean keepLooping = true;
while(keepLooping){
if(myTimer.isActive()){
Serial.println("Waiting for timer to expire");
delay(1000);
else{
Serial.println("myTimer.isActive() = false \n Now exiting loop!");
keepLooping = false;
And here is the output to the serial monitor:
Now exiting loop!
Now exiting loop!
Now exiting loop!
Now exiting loop!
