I have read through all the documentation regarding system.sleep()
and in each instance it mentions using a pin and pin mode in combination with the timeout. Much like
System.sleep(D3, RISING, 30, SLEEP_NETWORK_STANDBY);
I wanted to know if its required to specify the pin and pinmode or if the timeout and sleep mode can be specified alone?
System.sleep(, , 30, SLEEP_NETWORK_STANDBY);
or
System.sleep(30, SLEEP_NETWORK_STANDBY);
Thank you
