Hello everyone! this is my first post!
I want to know if i can use the memory of a sim card to save some data when the device don’t have signal? I look for it on the forum but i could’t find the answer
Best
Best
What Electron are you using? (2G, 3G, LTE)
You would need to do that via the cellular module on your device and the respective AT command.
https://docs.particle.io/reference/device-os/firmware/electron/#command-
I am using Electron 3G , Cellular.command() looks very interesting.
There are many commands that we can use, There are commands to save phonebook and to send messages. Do you know a simple command to save a string as a variable and then recover it?
The sim uses a EEPROM, if i constantly write data, could it be a problem?
Best!
Thx
Just out of interest, why would you want to write to the SIM and not use the flash memory of the controller?
@ScruffR, having the data on the SIM makes it portable from Electron to Electron I would think.
While true it would be good to know the OPs intent - if “SIM swapping” wasn’t the intended use case other options may be more beneficial to investigate.
