I’m using a SHt10 to read the soil humidity. I put a 10K resistor between data and Voltage.
The sensor is reading but I have readings I thing It’s not real.
for example, I put the sensor buried and alway is 93 or 94% when the soil is completely dry. I used another sensor to check and the measurements are 68%.
I re-checked puting in aerial mode and comparing with a bme280 humidity, and the readings for BME are 42% and sht10 30%. and with different Sht10 sensors…
does any body knows why I have this incorrect readings?
Thank’s
/////////////////////////SHT10 Reading/////////////////////////
digitalWrite(D2, HIGH);
digitalWrite(D3, HIGH);
float tempsoil1 = sht1x.readTemperatureC();
float humsoil1 = sht1x.readHumidity();
digitalWrite(D2, LOW);
digitalWrite(D3, LOW);
