Shortcut for loading examples in the build IDE?
Is there some short cut to opening a example from a library?
Or do I checkout the code and cut and past it into the IDE?
I will let the rest comment on all your thread but just dropping by to suggest that you can ask all your questions in one thread in point form.
That will make it easier for us to keep track and answer :slight_smile:
Theyare separate valid topics. Why clump them? That will make it harder for the next guy to find an answer.
I updated the topic of this thread to try and more closely match the question.
David
