Setting up a Predix Lab with Particle Hardware
I’m trying to get suggestions on hardware to setup a Predix Lab. Is anybody using particle with Predix?
I’ve never heard of Predix Lab. Can you provide a link and an explanation of what you want to do with it?
This is Predix … https://www.predix.io An Internet of Things API and Framework. I want to simply use Particle to report back to Predix.
If it can take HTTP/HTTPS as an input you can use Webhooks and Particle Publish to talk to it.
