Hi
Is it possible to extract values/readings out from Serial Monitor to Excel?
(Without using particle.publish, only using serial.print)
Hi
Hi, and welcome to the community!
I have not seen any projects like this in Particle myself, but I searched on the web and I got this that perhaps can get you inspired on how it can be done:
my original search:
https://www.google.com/search?q=arduino+serial+to+excel
cheers
Hi Gus,
I’ve tried the Data Streamer offered by Microsoft, however, it only works with Arduino.
No data gets streamed in when I tried with Particle Argon.
@tan, can you share your code or at least the parts writing out the values to the Argon Serial port? Indicating that you “tried” something without showing “how” you tried it makes it difficult for us to assist.
Hiii
Its a very simple code, all it does is read Temperature, Pressure and Humidity values from a BME280 sensor and publishes them via serial. I have been monitoring the readings using serial monitor from Particle Workbench.
#include <Adafruit_BME280.h>
Adafruit_BME280 bme;
if (!bme.begin()) {
Serial.println("Could not find a valid BME280 sensor, check wiring!");
while (1);
Serial.print("Temperature: "); Serial.print(String::format("%0.2f", bme.readTemperature()));
Serial.print("°C\tPressure: "); Serial.print(String::format("%0.2f", bme.readPressure() / 100.0F));
Serial.print("hPa\tHumidity: "); Serial.print(String::format("%0.2f", bme.readHumidity()));
Serial.println("%");
delay(1000);
@tan, looking at the examples for the Streamer, the names of the fields are not sent to serial, just the data. Also, I am not sure why you send the “%” at the end as this is not shown in any example, only the `Serial.println()" to force a linefeed.
Finally, using the “regular” Serial.print()
command, you can avoid the String::format() thing by simply specifying the number of decimals in a float
. For example:
Serial.print(String::format("%0.2f", bme.readTemperature())); become:
Serial.print(bme.readTemperature(), 2);
I couldn’t find an exact console output in that project, but how does your code compare to what they mention in step 7?
Serial.print(sensorReading1);
Serial.print(",");
Serial.print(sensorReading2);
Serial.print(",");
Serial.println();
I suggest you follow more closely what the streamer expects
To throw in another suggestion.
First avoid while(1);
in your setup()
as it will throw off the Argon’s cloud connection.
And for your data I’d go with
Serial.printlnf("%.2f,%.2f,%.2f"
If you wish you could add this in setup()
to emit the column header names
Serial.println("Temperature,Pressure,Humidity");
BTW, some localization call for semicolon (;
) instead of comma (,
) as column separator (e.g. German )
Some more digging revealed that this seems to be an issue with other micro controllers too (e.g. ESP32). The problem is that many modern micros with inbuilt USB won’t handshake the same way as Arduinos do (i.e. not sending an RTS signal) but MS Data Streamer expects that.
